Speedo pick up
Hey guys on a 32 non stepped hull where should I mount a pick up tube for the speeedo.I have seen some mounted on the notch and some mounted on the transom.Can any one post some picks of where theirs are and let me know how accurate they are..
Thanks Anthony |
I removed the stock pickup from the transom on my 27 Fever and hooked up my speedo to the built in B1 pickup.
Originally Posted by badluck
(Post 2906254)
Thanks Anthony |
No pics, but the ones I've seen are at the notch, close to the drain plug.
How accurate are these type of speedo's I have heard somany mixed reviews..... ????
John |
Sorry no pic, but mine is located just right of the drain plug. it actually is between the drain and the starboard water pick-up. gud luck
Originally Posted by Fenderjack
(Post 2907235)
John When I went from a pitot speedo to a gps speedo I lost about 3 mph top speed, I would tend to believe that the gps is accurate and the pitot was a bit optomistic. David |
[QUOTE=Fenderjack;2907235]How accurate are these type of speedo's I have heard somany mixed reviews..... ????
I have a 100mph Livorsi. At 75mph GPS speed the speedo is pretty accurate (within 1 or 2 mph). |
I got a new livorsy speedo.. tring to keep it the way it was when new..
Anyway it reads about 68 mph when the GPS say's 75. I have blown air theough the line etc.. the pick up lools like it might be bent back a litlle. I can't figure it out. It is mounted right on the center of the transome by the drain plug |
The B1 pitot speedo pickups tend to read faster, the higher you trim the drive. You can continue to "pick up speed" on the dream meter even when you are actually losing real speed, as you trim the drive too high.
| All times are GMT -5. The time now is 05:47 PM. |
