-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Lightning vs Executioner (https://www.offshoreonly.com/forums/fountain/220115-lightning-vs-executioner.html)
SPEEDFREEK 11-17-2009 12:00 PM
Does anyone know if the 42 lightning is faster than an Executioner with 525's and if so, why?
fountainracing65 11-17-2009 12:34 PM
because the lightning is more :coolcowboy:expensive!
dykstra 11-17-2009 02:32 PM
hull design
bcfountain 11-17-2009 03:32 PM
caus reggie said so!
RaggedEdge 11-17-2009 04:54 PM
Per the Fountain site ..........
42 Lightning w/ 525's XR ITS Short Sportmasters = 88 +
42 Executioner w/ 525's XR Short Sportmasters = 86 +
I would think the diff here of 2 mph would be the set back and likely higher X from the ITS. Tit for Tat I would think they would be a dead heat. In years past there was a difference in the hulls used, but I believe now they share the same hull and only the top deck is different. On older models where there would be a different hull design the speed difference would likely be greater.
The Lightning shows a dry weight of 11,400 and the EX shows same at 11,200 so the diff is not really due to weight.
iariverrat 11-18-2009 02:23 PM
I would think if they where set-up the same the Executioner would be a little faster because of the weight. As for the looks I like the Executioner's better, but that just me.
