-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   1997 29 fever ? (https://www.offshoreonly.com/forums/fountain/220645-1997-29-fever.html)
sirfartsalot 11-29-2009 04:52 PM
1997 29 fever ?
I'm in the process of buying a 29 fever twin 454 efi. Boat comes out of the hole pretty slow is their anything I can do to help this it has hydromotive 4 blade props. No cavitation just slow and bow very high after it planes out runs pretty good. Don"t know pitch yet still in buying process.
US1 Fountain 11-29-2009 09:58 PM
My 32 plains out fairly quick and level. Were the tabs and drives both all the way down? That'll make a for a slow, nose high take off if not.
BarryB 11-30-2009 02:07 PM
I have a 1991 Fever with twin 454's and it comes out of the hole very fast. I always put the drives all the way down, but I never touch the tabs. There is no need.
TampaBeach 12-01-2009 09:53 AM
I agree that boat should hop out of the hole, however what are you comparing it too??? If you previously had a inboard ski boat like a Mastercraft and I/O will be slow.
Just make sure drives are all in, tabs down, about half throttle maybe 3/4, and you should be up.
nick9671 12-03-2009 11:50 AM
the prop pitch can definitely affect that. I have a 98 fever same setup, I was having same problem so I changed props.....
