-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Fastest 29 Ever (https://www.offshoreonly.com/forums/fountain/221219-fastest-29-ever.html)
DIRT173 12-11-2009 08:03 PM
Fastest 29 Ever
Question? What is the fastest speed anyone has seen in a 29 late model fever? And at what point do things get really sKETCHY?
Roger 12-11-2009 09:17 PM
Mine runs 93 and you have to drive it. Twin 509s. Year is 95 small step.
t500hps 12-11-2009 09:38 PM
There was a guy locally that claimed the fastest 29 ever...something around 110 I believe. Kept killing XR's, then killed a couple Konrads, finally reduced power so he could boat on a regular basis.
(I'm close with these details but know I don't have them exact, hopefully someone will fill in the exact info)
kickin32 12-11-2009 09:57 PM
There is one on lake wylie that will do 119 with a quad rotor motor, single engine
DIRT173 12-11-2009 11:48 PM
There was a guy in Naples, Fl I talked to on OSO about a year ago that said he had a single blown CHIEF 598 and claimed his 29 did 105mph all day long. (if you read this please chime in!!)
TampaBeach 12-12-2009 11:47 AM
Thats scary, I guess every time he stopped "replace the drive check the gas":eek::party-smiley-004:
Beak Boater 12-12-2009 01:10 PM
I believe that was Thomas, with Crowd Pleaser.
t500hps 12-12-2009 02:04 PM
that's the boat......just don't know all the details. Of course that boat is famous without ever starting the engine!!!!!
Bullhead 12-12-2009 03:09 PM
I rode in the Crowd Pleaser at 105....definitely had to drive through some chine walking between 85 and 90....after that it wasn't too bad.....he was going through XR's like candy and then switched to a B-max....the B Max held up better but when he did have a problem he did not have much luck with the manufacturer....I agree with Russ...the boat's other attributes were much more impressive than its speed
rackster 12-13-2009 05:38 PM
I would like to hear some details about that 119 mph 29. I am most curious about which drive is being used, as well as HP.
BTW...The Crowd Pleaser was fastest with the standard XR drive and 6 blade Hering. We had the prop slip down to about 3%, so we were not wasting any of the HP.(May have wasted a little grinding up those Bravo gears:eek:)
