Triple switch on throttle lever
I'm thinking to replace the standard trim switch on the throttle (left pic below) with the triple switch below from Livorsi (right pic).
The idea is to be able to control also the tabs without taking the hand off the throttle. The fore finger switch could control the trim, and the 2 thumb switches the tabs. Seems a nice solution on paper, but I don't recall to have seen any boat with such arrangement. Am I maybe missing some reason why it's NOT worth having it? Not as practical as it seems? Troubles with wiring? Any views appreciated! http://i23.photobucket.com/albums/b3.../HL/single.jpghttp://i23.photobucket.com/albums/b3.../HL/triple.jpg |
Sunsation uses them on there new boats. I was thinking of doing the same thing, seems like a good idea.
Our 37 Outerlimits had trim on one throttle, and tabs on the other throttle. It had 6 drives, so once on plane you didnt trim the drives very much at all. It was easy to concentrate on the tabs switch and not get confused. On a bravo drive boat, when you are trimming alot, it would take some practice to remember which switch you are pushing.
Looks cool, wonder how it would tie in. Think it would work perfect better than stering wheel controls.
Looks slick. I get all confused just trying too remember which of mine are for the tabs and which one is for the drives.:) My switches control both drives and both tabs, no independent adjusting. Not sure if having sep tab switches at your fingertip would be all that benefical??? A common one is nice though.
Wouldn't be too hard to install, just gotta add some diodes for the tabs switches, or tap into the individual side of the dash switches so they don't back feed. The drive switch is no problem. |
Originally Posted by US1 Fountain
(Post 3055388)
Funny that apparently nobody is using them, maybe I should relay the question on the general q&a. |
Sunsation has them on their boats try that forum.
I'll give it a try, thanks.
Do you think that as a Fountain fan I should fear the reaction of Sunsation guys...? :lolhit: |
How about a double switch on the throttle. One for the drive, one for both tabs at the same time. If you have an uneven load and need to trim separate then you could still adjust them on the dash right?
Yes of course, but I don't see why not to have the separate controls also on the throttle if you can.
Besides, if you use the "normal" dual switches, and wire them as one for the trim and the other for both tabs, I'm not sure you're really getting a better control. In my mind, it's more convenient to use the fore finger and the thumb for separate purposes, than just the thumb for both. I'd be curious to hear from someone who actually tried this triple thingie. But sunsation forum doesn't seem as lively as this one... |
The wires are really small, so I don't see that being an issue since this is what you want. Wire it up. :)
I made my 2 switches to run the drives and tabs without any independent control mainly just for ease of taking off and trimming. Rarely do I ever trim the tabs differently, so I didn't need a 3rd switch. Easier to hit both swithes to lower both the tabs and drives on the lever than on the dash. |
| All times are GMT -5. The time now is 06:42 AM. |
