cooler drain >
cooler drain
cooler drain
Old 04-13-2010 | 05:54 PM
fourplaydave69's Avatar
Default cooler drain
Could someone tell me in which direction the hose goes from the cooler? And does it attach to anything? Thanks
fourplaydave69 is offline
Old 04-13-2010 | 07:17 PM
Mine at first just ended under the cabinet so I bought new clear hose and routed it to the back so it would drain into the bilge area. It took all of 30 minutes to do and no problem since
tbrown15239 is offline
Old 04-13-2010 | 08:12 PM
Mine connected to the sink drain,,,,,,,,, not the best way, it's lower then the sink drain when boat is siting in water.
Wildman_grafix is offline
Old 04-13-2010 | 08:51 PM
mine also connected to the sink drain at one time now it drains directly out the side of the boat witha thru hall fitting. works great
malo29 is offline
Old 04-13-2010 | 09:31 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Mine was routed onto the top of the gas tank when I 1st got it. That would be the same compartment that has no drains! Figure that one out.
I also ran a drain hose underneath the floor and out one of the drain holes into the bilge if I ever wanted to use the cooler. There is a small gap between the floor underneath side and the bulkheads where the hose can pass thru. Remove the gas tank inspection cover to help feed the hose thru.
US1 Fountain is offline
Old 04-14-2010 | 08:27 PM
malo29 , how do you think it got connected to a thru hull fitting ? how come it works so good ? ha ha
tim brown is offline
Old 04-18-2010 | 09:20 PM
I would say it works so good cause tim brown did it...
malo29 is offline
Old 04-18-2010 | 09:56 PM
Ginger or Mary Ann?
Never met a man afraid to drill a hole thru the side of someone elses boat.
Old 04-21-2010 | 08:37 PM
Thanks for the replies.
Old 04-21-2010 | 09:24 PM
it was mine when I drilled the hole , I need to do the samething to my 35 . don't be scared .
