-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Drive swap (https://www.offshoreonly.com/forums/fountain/22891-drive-swap.html)
Chummy 04-23-2002 11:30 PM
Drive swap
A Buddy of mine recently swaped the drives on his 38 Fever so that the props turn inward instead of outward. He was told it would have better bow lift, but now it doesn't seem to have any bow lift. Any advice will be appreciated. Thanks
candyman35 04-24-2002 12:23 AM
Chummy,
With Bravo drives you just need to run the shifter in reverse and reverse the props to spin the other direction for testing. Turning the props in won't help with bow lift and probably slowed his boat down. Fountain started running the props in on his step hull boats. What year is his 38'? What power, props, drives? Certain props will give you more bow lift others lift the stern.
Dan
Chummy 04-24-2002 05:22 PM
Its a 89 with 454's with blowers and TRS drives. It did slow down a lot. We are putting them back tomorrow.
E Z TERMS 05-02-2002 03:14 PM
depending on the props .........it'll lift the stern a little or a lot........
mine turn in..........they make it a little faster..............but its not worth it......................drives like crap around the dock and makes it drive spooky over the crest of lengthwise waves
just my .02
ez
50boat 01-30-2005 08:10 PM
Re: Drive swap
:drink: switzing drives was work you didnt have to do . ok know heres a thought put on a 100 hours or so , then trade drives, and props, ok know you will be running on the back side of the gear. to ballance wear. go anouther 100 hr and swop back :chimp:
Zanie 01-31-2005 07:26 AM
Re: Drive swap
Read post #3!
It's a TRS boat!
Dedicated L&R drives!
Back4More 01-31-2005 07:43 AM
Re: Drive swap
With that year Fountain they need to spin out....What props are they?
Wally 01-31-2005 09:31 AM
Re: Drive swap
On TRS drives you DO have to swap drives.......you cant run the trans in reverse to go forward.....it will burn up the clutches in no time!
aTX427 01-31-2005 01:33 PM
Re: Drive swap
my 2000 38 lightning spins in
H2Xmark 01-31-2005 06:27 PM
Re: Drive swap
[QUOTE=E Z TERMS]depending on the props .........it'll lift the stern a little or a lot........
just my .02
Hey whats going on??? are you going to the TOPPS [turtle club] meeting this Friday night ?? I wont be able to make it but will catch the one in March at Crawdaddys
Mark Rush
H2Xmark 01-31-2005 06:33 PM
Re: Drive swap
Some people get spinning in and out backwards, I always went by looking at the back of the boat the starboard prop turns counterclockwise is spinning in, whick should give more bow lift and spinning out gives more stern lift[but a more stable ride]
Edward R. Cozzi 02-15-2005 12:48 PM
Re: Drive swap
Turn the props out and try different style props to achieve what you're looking for.
