-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   29 Fountain Prop ? (https://www.offshoreonly.com/forums/fountain/235249-29-fountain-prop.html)
dboater1 07-21-2010 08:04 PM
29 Fountain Prop ?
I have an 04 29 w/factory sealed 525. the boat had full time mufflers on it when i purchased it. Since then I have removed the mufflers and added sport tips. The boat has 26p bravo one and is on the rev limiter in all weather conditions. Gonna try a 28p. what props are other 29 fountains w/ same power running, and whats the top speed. Im anywhere from 71 to 76 gps with the 26.
paulsgts 07-22-2010 09:05 AM
I have a 03 29 with the 525 and I'm runnning a 28p. With 5 or more people and a lot of fuel I switch it to the 26p. Not sure of my top speed got the boat a few months ago and waiting for my GPS antenna to come in.
chewspit666 07-22-2010 10:59 AM
I ran a 27 hydro it worked great all around, it ran at 5400-5450 78-80 all the time
bob_t 07-22-2010 11:39 AM
My 2006 29 Fever with 525 EFI currently has a 26P B1 prop. In warm weather (when most of us run our boats) with mostly full tank of fuel, 3-4 adults and our 2 kids, we run ~ 76- 78 mph on GPS, and hit the rev limiter or rare occasion. When it cools down and lighter load, it bounces off the rev limiter more often. I would think that a 28P would be too much prop for "average" summer running for me. I think it would strain the engine too much trying to get on plane (which would be more of a struggle, too). Engine is bone stock 525 with 115 hrs on it, no mufflers.
dboater1 07-22-2010 05:59 PM
Thanks Guys!
chewspit666 07-22-2010 07:01 PM
Is yours left or right handed
Mark D 07-23-2010 03:26 PM
26 pitch on a lefty drive...
I can get to 80 if I try, empty water tank with the boat aired out trimmed, tabbed, and good current.
It helps if I am trying to catch Chewspit666 so I can prove his red boat isn't any faster that my blue one.
chewspit666 07-23-2010 03:53 PM
Hey Mark i'll toss u a rope and pull that blue boat to 80:evilb:
bob_t 07-23-2010 05:50 PM
The factory test sheet on my boat showed a 28P LH B1 prop. Boat ran 81 mph, but it was tested in December and test sheet says 38 degrees temperature. In 2005, or thereabouts, Fountain lowered the X dimension 1/2" from 19.5" back to 19". My boat has X of 19". I have test sheets from several 2003 and 2004 29's with 525's and they were all 19.5" X dimension. Most of those had either 26P or 28P B1 props and top speeds on the test sheets between 77 mph and 80 mph. Our previous 29 with 575 SCi had X at 19.5". Test sheet on the 575 boat was 83 mph with 30P RH B1 prop. We tried several props on that boat and could never get on plane with a Hydro QIV prop. No problems getting on plane with the B1 props. With the Hydro QIV props, as soon as the bow started to come over the prop lost its bite and just blew out. Tried every way we could think of to get it on plane and never could with the Hydro prop.
dboater1 07-23-2010 08:40 PM
Test sheet shows X demension at 19 1/2, 50 gal. fuel, 75 degrees, and calm water. remember the boat had full time mufflers from factory. 78 mph.The tattle tale since ive owned the boat shows 76. the drive is RH. Gonna try a 28p bravo this weekend, Ill post the outcome?The problem is its been 95 and 100 % humidity here in western KY.
