-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   k plane ? (https://www.offshoreonly.com/forums/fountain/239421-k-plane.html)
money455 09-20-2010 01:20 PM
k plane ?
i have factory k planes and they work great but, when using the switch that controls them at the same time one works faster than the other up or down . shouls i care about this or is this normal , how do i change the fluid in them . there is a flat head screw that is turned half way out on both pump bodies what is that for ? any help is appreciated .
1980Condor460 09-22-2010 08:47 AM
I'm not sure if this helps but mine do the exact same thing. I get them about where I want them then fine tune with the individual switches. My drives trim at different rates as well.
Back4More 09-22-2010 10:49 AM
Bought new pumps once and they are still off a little in speed vs each other....same with my drives.
Bad Girl 09-22-2010 11:12 AM
mine too
my port is 2 times faster. I just bought a used pump to get the pump body out and switch it.
Ted G 09-22-2010 11:17 AM
You need to open the motor up and clean the surface the brushes ride on, they get corrosion there and slow down.
spazboz 09-22-2010 12:30 PM
While your in there grease the bushing between the valve body motor. They get dry and turn hard after a while too.
money455 09-22-2010 02:37 PM
thanks for info guys , i will try cleaning the motors and see what happens . does the bottom (large oil filter looking part ) un - screw and thats where the fluid is
