Dash Refurbish Help >
Dash Refurbish Help
Dash Refurbish Help
Old 03-21-2011 | 09:57 PM
  #61
Originally Posted by leonard
Does anyone know where you can find these gauges? gaffrig has discontuined them, I think I have a faulty oil pressure gauge. The needle jumps from 80 to 60 to 20 to 40 to 60, 40, 20, 0 then alarms! Only at idle, only on the water. I'm going to shoot a video of this when I go out again.
I'm sure you've already checked, but I would make sure the connections at the ground and sender are tight. ts27
Thunderstruck27 is offline
Old 03-22-2011 | 07:55 AM
  #62
leonard's Avatar
I have replaced the sender with a new one from gaffrig. Doesn't the sender take it ground right off the motor? When I took the older one off (which looked pretty new like someone before me has tried this) it had looked like they had put silcone on the threads....but the new sender did the same thing. I have just did an oil change with new filter we shall see once I'm out on the water because I cannot create this problem while she's on the trailer. For 3 years my solution has been after the alarms go off shut down reset the motor start it up and leave it in neutral to raise the rpm's to keep the pressure up while getting out of the bay. Once the 5 mile and hour bouy is past she good to go!
leonard is offline
Old 03-22-2011 | 09:16 AM
  #63
maybe i missed something, where does it say livrosi?
Send it to Livorsi and they can fix it. If they can't I am getting all new gauges for my 47' Fountain and I will have plenty of old gauges.
dewayne6243 is offline
Old 03-22-2011 | 09:39 AM
  #64
leonard's Avatar
Thanks dewayne6243,
Beggers can't be choosy but are they the discontuined gaffrig Redline Series like the one below?
Attached Thumbnails Dash Refurbish Help-img_0155.jpg   Dash Refurbish Help-img_0156.jpg
leonard is offline
Old 03-22-2011 | 10:40 AM
  #65
You're right about the sender, but the ground I meant was at the gauge...just a shot in the dark. I'm no guage expert, but that's the 1st thing everyone told me to check when I was having trouble with my guages. Turned out that just about everyone of them were loose.
Old 03-22-2011 | 12:04 PM
  #66
leonard's Avatar
Hey Thanks I just got a new gps speedo when I replace my old liquid filled I will check out the ground leads.
thanks for all the input everyone
leonard is offline
Old 03-25-2011 | 04:44 PM
  #67
Originally Posted by RunninHotRacing163.1
love to see pics of a completed one
Obviously I dont have a fountain but this might give you an idea of what vinyl can look like..Its a great way to update a dash without spending an arm and a leg. I only spent about $75 having this vinyl designed, printed and shipped.
http://www.offshoreonly.com/forums/p...ml#post3359687
Powerquest_Baby!! is offline
Old 03-25-2011 | 04:49 PM
  #68
WOW what a difference that made i was hoping you were gunna change that cup holder
Old 04-02-2011 | 11:34 AM
  #69
leonard's Avatar
here are those pics sorry it took so long I had just got a new GPS speedo and wanted to install it before i took the new pic. The lights are not much different but i like trying to keep it original looking
Attached Thumbnails Dash Refurbish Help-img_0160.jpg   Dash Refurbish Help-img_0016.jpg
leonard is offline
