-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   35 Lightning Hyd steer question (https://www.offshoreonly.com/forums/fountain/249135-35-lightning-hyd-steer-question.html)
frenchfri21 03-10-2011 01:54 PM
I was having a new stereo insalled, and they nicked one of the hyd. lines:angry-smiley-038:. They replaced it, but i believe i will have to bleed it. Am i correct, or is it a self bleeding system. If i do have to bleed it, how?
acaruso 03-10-2011 07:31 PM
fill the resieor start both engians turn the sraring wheel lock to lock
RaggedEdge 03-10-2011 07:41 PM
What he said!:drink: Should do the trick for you.
monstaaa 03-10-2011 08:56 PM
just in case you may want to crack the lines on the rams while in full lock just to make sure there is no air left behind..
frenchfri21 03-11-2011 08:14 AM
I will try that. So it is a self bleeding system? Thanks for the help.
