Fever sending unit
I have the 7822 fuel sending unit in my boat, does anybody make a direct replacement for this sending unit or do I have to purchase it from Fountain.
http://i234.photobucket.com/albums/e...vegas002-1.jpg |
Sending Unit Removal
I had to replace mine years ago and found the supplier to Fountain. I'll look around to see if I still have their name.
Also, be very careful when you start removing the sending unit. You have an aluminum tank with an aluminum sending unit. The threads can gall easily. I found the best way to remove the unit is to: 1. Spray penetrating oil on the threads. 2. Vigorously tap the assembly with a hammer as you try to unthread the unit. The impacts will help the unit unscrew. If you have trouble adapting a removal tool, I actually have one that was fabricated to go over the unit with a 3/4 inch socket attachment. |
| All times are GMT -5. The time now is 03:06 PM. |
