-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Need info for prop size (https://www.offshoreonly.com/forums/fountain/249303-need-info-prop-size.html)
pacalim1965@yaho 03-13-2011 06:49 PM
I just purchased a 1998 29' Fountain with a single 540 700 H.P. motor, It also has a Imco Extreme Advantage OutDrive with 2' shortie. What prop would best fit this combo? Any Info will be greatly appreciated Thanks- Patrick
Griswald 03-13-2011 09:27 PM
Have you run the boat? What prop is on it, now?
pacalim1965@yaho 03-14-2011 09:17 AM
I have not ran the boat yet, It came with a 26 Bravo 4 blade. That was with old hp-500 motor set up.
NEVERSATISFIED 03-14-2011 01:34 PM
My 97 had a 565ci. that dyno'd 725hp I used a hydromotive 28 and spun it 5800
rexcramer1 03-14-2011 02:59 PM
Is the motor supercharged or NA? I would think you would want to keep the rpms higher for an NA motor
pacalim1965@yaho 03-14-2011 09:23 PM
The motor is n/a, At what rpm should it spin at?
Ran-Dom 32 03-14-2011 09:31 PM
5500 - 5600, I would try a bravo 1 30P:boat:
pacalim1965@yaho 03-14-2011 09:43 PM
I currently run a Bravo 30 on my 27 Baja Boss 509 m3 Procharged. I thought a 30 would be to big for the Fountain only puting out 700 HP.
Ran-Dom 32 03-15-2011 08:40 AM
only 1 way to find out... try it, the Fountain will have a much more efficient bottom vs 27 Baja
Griswald 03-15-2011 01:54 PM
call Brett a BBLADES and try a few different props from their loaner program.
29Fever575sci 03-17-2011 08:57 PM
I run a left hand 30 pitch bravo 1 on my 2002 29 but with a blower, not na. Little over 700hp but big torque.
A buddy of mine had a 1998 or 99 29 fever and ran a 27 hydromotive left hand clever style 6,000 rpm's (blower) around 90mph.
I read that Fountain changed the bottom or x dimension around 2000+ and the bravo 1 is the best prop for those newer hulls but the older bottoms like the clever style.
With the 2" shorty it is a crap shoot and testing is the best way.
Mine came from the factory with a 30 bravo 1.
Keep us updated on your testing. I was wondering how that setup would run.
I'm thinking about a nose cone since being above 85mph I heard they help slip alot.
pacalim1965@yaho 03-18-2011 08:24 AM
Today im pulling the Stock bravo 30 prop off my baja and trying it out on the fountain. I will keep you posted.
pacalim1965@yaho 03-21-2011 04:50 PM
At wot Running a stock 30 bravo maxed my rpms at 5400.
pacalim1965@yaho 03-21-2011 04:56 PM
Does anyone know what a 31 Herring 6 blade prop would do on this combo? Currently im using my tabs to get on plane, Probably because of 2' shortie. Would a 6 blade add to much stern lift? How would the bout ride with a 6 blade? Thanks
Griswald 05-06-2012 08:42 AM
any updates to this thread?
