-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Transom Light Replacement (https://www.offshoreonly.com/forums/fountain/251068-transom-light-replacement.html)
The Landlord 04-09-2011 06:07 PM
I have a 1984 10 meter. I am wanting to replace the transom light, preferably with a LED. The factory cut out opening is 2.25" tall and 5.25" wide.
Does anyone know where to get a new replacement for this light?
I would like for it to be white or if it is all metal I could have it powder coated.
Thanks in advance!
pitts1313 04-09-2011 10:30 PM
Perko website be a good place to look, see if they have one that size or close. Might have to trim hole a little bigger if you find one that is close. I had to trim mine for a replacement transom that was round.
bcfountain 04-10-2011 07:52 PM
dana marine has a replacement for your boat.i got one in powder-coated blue.it is a dirrect replacement.
The Landlord 04-11-2011 06:16 PM
I found one on Dana Marine and emailed them to make sure the size is correct. Do you know what the item number was?
