-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   27 Fever- Optimum SS Propeller (https://www.offshoreonly.com/forums/fountain/251123-27-fever-optimum-ss-propeller.html)
JRPInd 04-10-2011 04:50 PM
I'm running a 14 x 24 4-Blade Mach Stern Driver SS propeller. Boat gets on plane decent, Top Speed at WOT: 5200 RPM K-Planes All the way up on 1, 1/2 tank fuel, Drive at about 2.5, slight chop at the water surface, just me a my girl in the boat (shes weighs a buck 20 soaking wet and I'm 190#), she'll give me 70 mph on the speedo. Does this sound right? The Boat is powered by a 502 Mag MPI with about 260 hrs on it and it's bone stock. Just want to be sure and want to know if there are any better props out there i should try. Thanks for any input. JP
ttuton 04-10-2011 08:12 PM
Sounds real close to me.
mcprodesign 04-10-2011 08:25 PM
I got a mach. runs about 72 MPH, and another Prop,( Bravo 1), I put about a grand into, and it goes 77 w that. (GPS)
JRPInd 04-11-2011 08:53 PM
A grand for for 5 mph...i wouldn't mind trying that. who did your prop work?
mcprodesign 04-11-2011 11:42 PM
Brett at B Blades. he is here on the forum somewhere. He let me try one first to see what would work on my boat. Friggin Prop just Locks solid . I love it
rjcardinal 04-12-2011 08:20 AM
I have a Left Hand Labbed 26" Bravo that would be perfect for your boat.
The prop was labbed by Mercury Racing and is stamped.
I have the original box also.
$400.00 plus shipping.
Should get you 2-5 mph.
Ron
tutzone 04-15-2011 08:31 AM
I have a hp500 running in a 27 Fountain.I was running a 27 x 14 1/2 mach @ 76 mph @5100 rpm's.The prop got damaged and i sent it to bblades for repairs.When i got the prop back i now run 69 mph @ 4500 rpm's.I have sent it back three times with no improvements.I am very disappointed with bblades.
JRPInd 05-16-2011 11:39 PM
Ron
I'm interested. Do you have any pics? What condition is it in? Was it used since it was labbed?
Thunderstruck27 05-17-2011 12:55 PM
I don't want to piss on anyone's parade here, but you may loose some RPMs with a 26p Bravo I blade. And you know what that will do!? Just m:drink:y 2 cents
Petesflht 05-18-2011 07:51 AM
stock prop on mine was the 26" Bravo... that sure is the right prop for mine..
Thunderstruck27 05-18-2011 12:51 PM
Apples and Oranges!!!:drink:
EarlyInheritance 05-18-2011 07:16 PM
Pete what MPH are u getting out of yours?
Petesflht 05-18-2011 10:01 PM
When i was stock I would get the 67ish and now 75.
Aaronl325 05-24-2011 02:28 PM
I just ran mine over the weekend. 4 people and full tank ran 75mph. Tabs at 2 and drive at 5. I've only had mine out a couple hours so far.
What's the best setting for the tabs/drive to start at when getting on plane? Just want to be as easy on the drive as possible.
Thunderstruck27 05-26-2011 02:19 PM
Coming out of the hole I run my drive all the way in and my tabs all the way down...
topfueleb 06-01-2011 04:21 PM
Tabs full down and drive all the way down also. then pull tabs up then drive.
JRPInd 09-30-2011 07:00 PM
Bought the labbed 26 Bravo
what a difference
75 on the speedo all day long with 4 people full of fuel (compared to 68 with the Mach)
i forgot the rpm, tabs and trim nos.
i'll post them next year when i get her back in the water
boat feels more stable and smoother and it planed even better
the prop woke the boat up
27fever1994 08-23-2012 06:01 PM
1994 fever 27 new crate engine 5026TX 415HP MPI old bravo 24 running 66 -67 MPH at 4900RPM-5000RPM
prop shop gave me a 23 revolution to demo last weekend 5000RPM 65 MPH . 24 was much better getting on plane. but it is old been repaired that can only explain none or little RPM change.I am going to try a bravo 1 26P demo this weekend hoping for better results .any input would be greatly appreciated.
tdpb2008 09-30-2012 01:23 PM
How did you make out with the 26 I'm it the same boat and want to get close to 70...I'm thinking of getting a labbed bravo 1 24p from Brett, seems like he's been getting the 70-72 out of a labbed 24 from what I've been reading
