unused water pick up's ??
1 Attachment(s)
My 98' 42 & my buddy's '97 38 both have what look like factory installed water pick up's under the notch, His only has 1 & mine 2, there are hoses attached that are just stuffed up on the sides of the engine compartment (not conected to anything). Were trying to figure out what they are or were for. I'm thinking possible for a/c & or gen set, if the boats were optioned out that way. Anyone else have these?
RL, break suction in back created by notch. Just my guess.
P Rob |
X2, I think it also helps the props slip a little while coming out of the hole, let's the motors build rpm quicker with some aeration.
That's what I originally thought, but James boat only has 1
Originally Posted by Ran-Dom 32
(Post 3378530)
My 1997 47' has 2 in the same place as the pic above, Prop aerators. I have AC and Generator and there are other pick-up for those.
Originally Posted by pitts1313
(Post 3378524)
Some of them have ball valves on them to regulate the amount of air to the Notch |
Originally Posted by blownincome
(Post 3378768)
:party-smiley-048:
(Post 3378768)
:party-smiley-048:
Some of them have ball valves on them to regulate the amount of air to the Notch My boat doesn't have these. I can see where it would help. there are a lot of strange noises coming from there getting on and coming off plane. |
If you are trying to get rid of air pressure at the props should you not route the hose's over board instead of plugging them up?
I've never looked in the bilge to see where mine are plumbed. Just put GAS in and go straight ahead. |
| All times are GMT -5. The time now is 06:52 PM. |
