-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   bathroom filter on a 47? (https://www.offshoreonly.com/forums/fountain/251699-bathroom-filter-47-a.html)
eddie 04-18-2011 04:05 PM
Where is the bathroom (vacuflush toliet) vent filter on a 47, smells like mine needs changed. I've looked around some and can't find it :angry-smiley-038:
redbud35 04-18-2011 08:14 PM
Quit pooping in there.:party-smiley-004:
Shallow Minded 04-18-2011 08:17 PM
Light a candle... :lolhit:
leonard 04-19-2011 08:03 PM
I have a 1997 47' and I didn't even know there was one but if you find it let me know.
DollaBill 04-19-2011 08:25 PM
Filter????????????????
eddie 04-19-2011 08:58 PM
1 Attachment(s)
I've replaced them before on other boats, I called Raymonds service dept today and the tech was like, have it pumped out and add some chemicals.
They are around $100 bucks so I'll try that.
Here's the info on them:
Dometic holding tank vent filter stops odors from escaping through holding tank vents. Contains odor-removing filter materials to keep your boat smelling clean and pleasant. Each filter is good for an entire season, and is easily replaced for a fresh start.
Includes mounting brackets and hose adapters. Available with 5/8 inch (16mm), 3/4 inch (19mm), 1 inch (25mm), and 1-1/2 inch (38mm) hose fittings.
DollaBill 04-19-2011 09:09 PM
You can replace the filter but if the head is used on a regular basis after cpl years a layer of waste will build on the bottom of the tank and won't be removed during pump out. The tank needs to be professionally cleaned or replaced to get rid of the smell
US1 Fountain 04-19-2011 09:32 PM
a proper vented holding tank won't need a filter. A good supply of air will allow non odor bacteria to be present in the tank. Poorly designed vent systems, too small, verticle, non straight hose runs allow for a odor emitting bacteria to be present. Both types of bacterial can not be present at same time.
Just a tid bit I learned recently from a previous owner of Raitan marine systems and author. I didn't make that chit up. :)
Also if not pumped out often or flushed well when doing so, the tank and hoses can and do absorb the odors. Only fix then is replacement. Neither items are life long. Filters do work, but are a bandaid more than a cure. That said, I installed a filter and it eleminated the odors.
38fountainecman 04-20-2011 12:53 PM
If you choose to just replace the filter, there is a kit that is sold on e-bay for $20.00. Basically, you cut the filter in half and empty out the carbon. Next, glue 1-1/2" threaded male and female pvc fitting on each half of the filter. There are 3/4" foam pieces on each end of the filter that hold the carbon in place. You will need to create one more 3/4" foam piece to hold the carb in. Replace the carbon (get active carbon from the aquarium store) and screw the two pieces together. Then you can periodically replace the filter from time to time at little or no cost.
eddie 04-20-2011 05:45 PM
I've got a buddy that cut his in half and used duct tape to put it back together. Said to get the carbon from pet store too. Problem is I can't find the filter to replace it! :lolhit:
snapcracklepop 02-10-2013 09:20 AM
Can you tell me where the tank is and how i access the hoses?
Jan tunem 02-11-2013 10:45 AM
Check the toilet for rot
