instrument panel
1 Attachment(s)
everybody post a pic of your dash panel, Mikes looks great with the purple panel!
1 Attachment(s)
Mine's basically the same as yours, without the throttle bezel. Also, I have the trim-in-wheel on all three spokes. There's now a GPS mount where the mirror is in the picture.
1 Attachment(s)
Here's mine. Just got the boat a month ago. I have been going over all the standard maintaince items first but then will order red bezels for everything.
1 Attachment(s)
Indy27,
Is that your boost and fuel pressure up there? What bugs me is where Fountain put my depth guage. You can't read it while standing. Mine's a 99 27' You'd think they would standardize the cutouts, but when you look at the back of the dash, it's all hand laid out with X's. Anyway: |
yeah, thats my fuel pressure and boost, I just installed the depth finder and mounted it a little lower than Fountain does so I can see it sitting or standing.Where is the transducer mounted in your boat?I cant get a consistent reading in the engine bay and under the step going down into the cabin I dont see anyway to get in there without cutting a hole!
Indy,
My transducer is underneath the step going into the cabin. On mine, you can lift the step. There's a bilge pump located in the compartment. The on the port side is a plastic deck plate where the transducer is located (slightly left of the keel). The depth gauge has never given consistent readings though. There's a guy on this forum, US1Fountain - Jerry who's got his mounted in a PVC "well" in his engine compartment. I recall he got pretty good results with that configuration. Also, what kind of blower set up are you running? BTW, my dash came that way from Fountain. You can see from the picture that it's not centered as well. I think Reggie's fairly short so it probably works ok for him. Thanks, Mark S. |
Mark,
the step in my cabin lifts up but it all carpeted inside with a stainless drain plug in the bottom. I am running a Stage II Procharger sc at 5 lbs boost. |
1 Attachment(s)
I finally bought a digital camera. This is a Team Marine replacement dash. The white dash from Fountain turned yellower than my wheel. Any suggestions on were to buy a NICE looking wheel that would work with the trim switches?
| All times are GMT -5. The time now is 11:11 AM. |
