| 35 White Lightning |
05-23-2011 07:57 AM |
It is easy just went through it, however I did need to re adjust the cables to the right length, diaconect the cabes at the throttles (2 phillips screws you need a short screw driver) mark the cables as you take them loose, then take out the 7/16 bolt and the cable is free. Repeat 3 more time cut the neutral saftey switch wires on bolt shifters, remove the throttlers. If you go on the Livorsi site under tech tools and go to throttles there is a how to, but it is easy if you don't mind standing on your head for a while
