Shorties on 38 small step fever or lightning
Who has em!? Picked up a pair of 2inch Imcos. Running stock merc 500hps. What prop is the prop.?How do you like them?
RAF |
I picked up about 4 - 5 mph when I went from standard length sportmasters to the -2's imcos. So far Px-5's have work well.
If you get your cooling water from your XR lowers you will likely have to install pressure relief valves when you switch to imcos. The water inlet for the imco's picks up a lot more water and you will likely blow off your cooling hoses if you don't have a relief valve to dump the excesss overboard. |
Thanks. I have stock Bravo drives with Gil sea strainers. I have a set of 29p Hydro p5xs. What do you think. Motors are stock merc 500hps
Thanks RAF |
keep us posted on your results have same 38 lightning small step and i've thought about doing same. good luck
| All times are GMT -5. The time now is 03:12 AM. |
