-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   What is this? (https://www.offshoreonly.com/forums/fountain/261779-what.html)
lslavick 09-06-2011 03:27 PM
What is this?
I have a 2005 29 Fever and found this under the cabin step in the round access panel on the port side. It was not mounted... But looks like it may have been at one time.
http://vgallery.slavick.com/Preview/Fountain/photo3.JPG
29scarab10 09-06-2011 03:34 PM
Tranducer for depth finder
lslavick 09-06-2011 04:04 PM
That is what I thought. But, I don't have a gauge in the dash and the build sheet shows that the boat was not ordered with a depth finder. Is this the normal location for the transducer? Is it normal for the factor to install the transducer without a gauge? Or, I wonder if this was an attempt to add a depth finder?
Wildman_grafix 09-06-2011 05:36 PM
That is the normal place.
Let's see a picture of the dash, a lot of people put a stereo remote where the gauge normally goes
US1 Fountain 09-06-2011 07:08 PM
Mine never worked mounted in the same location.
HaulinGas 09-06-2011 07:10 PM
Mine that came oem works great, mine is mounted in the engine room.
FuelinAround 09-06-2011 07:17 PM
Ditto transducer
Wildman_grafix 09-06-2011 10:04 PM
I put a new one in the same place, it was a different style, works great.
Seems to be good up to 40-50 mph, after that I never really look.
lslavick 09-06-2011 10:25 PM
Thanks for all the info.
Wildman, I don't have a picture of the dash handy but there is a place for the gauge. It currently has a Fountain emblem plate there.
How to I remount the transducer to the hull?
What gauge to I need to purchase for the dash?
lslavick 09-07-2011 09:06 AM
Pic of the dash. The filler is in the center below the speedo and tach.
http://vgallery.slavick.com/Preview/...Dock%20016.jpg
Wildman_grafix 09-07-2011 09:20 AM
Yea that is where they normally put them.
You may have a newer style transducer, call livorsi and tell them how many pins are on the wire connection.
It should be under the dash, if not I just ordered a new gauge and transducer.
It comes with instructions on how to mount it. Easy job, just make sure you don't have any air bubbles in the expoxy that is sent.
lslavick 09-07-2011 09:30 AM
Thanks for the help!
