-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   2000 35 Lightning Prop Suggestions (https://www.offshoreonly.com/forums/fountain/261822-2000-35-lightning-prop-suggestions.html)
C.I.M. 09-06-2011 10:28 PM
I have a 2000 35 twin step with 500 efis. It had a 17.5 x dimension, but I raised the drives and motors 2". Still stock bravo 1s with 1.5 gears. So far I have picked up 5 mph, but can't seem to find the right props. I can't get it on plane with 4 blade hydros. 30 bravos and it jumps right up, but runs right at the rev limiters at 87@5500. Just this last weekend I tried a set of labbed 32 bravos, RPMs didn't change but it ran 90@5500. Can't seem to get the RPMs down. Do I need to try 5 or 6 blades? Or try 34s? Don't really want to put out the money for herrings.
triple 300s 09-06-2011 10:56 PM
Originally Posted by C.I.M. (Post 3497391)
87@5500
how much faster are you trying to go on 500s and stock B1s? lol
C.I.M. 09-07-2011 07:48 AM
The faster the better.
Kelly O 09-07-2011 08:33 AM
On my 03 35 with a 18.25" X Dim, I got prop blowout over 90 mph using 32 B1 prop. RPM's would increase with no speed increase, I blamed this on the lower gearcase.
Added nosecones to stock lowers and switched to a Merc labbed 32 Maximus 5 blade 15 5/8 dia. and picked up 4 or 5mph top end and 6 mph at cruise speed.
Seems with your raised drives you would benefit from more blades.
Beak Boater 09-07-2011 08:49 AM
Using your numbers your slip is about 17%, which is not terrible, but a little high. 5 Blades may help get that down, are you running stock Bravo 1 drives with small propshafts, or the XR's? The 5 Blades may cause some drive issues. Raising your drives have your props surfacing some now and the load and unload of those surfacing props can be hard on propshafts.
C.I.M. 09-07-2011 11:54 AM
Yes i just have 1" shafts. I figured I would leave it alone until it breaks.
I was planning on doing some nosecones over the winter. I was thinking the mercury 5 blades, they are still a little less than herrings, right? Where do I start with pitch and size?
C.I.M. 09-17-2011 04:42 PM
are the hubs the same for the bravo's and the maximus?
47 lightning 09-17-2011 07:48 PM
You're saying you have raised your drives and motors up 2 inches...did you really raise the motors and drives or did you just raise your drives 2 inches? What is your total x dimension now?
Reggie Fountain 09-17-2011 08:05 PM
A five blade max would help, but a six or seven blade hering would be better.
triple 300s 09-17-2011 09:38 PM
I can tell you are in love with 7 blade herings! :lolhit:
TRL505 09-18-2011 09:11 AM
Agreed.....
Triple 300's likes to "cruise and chat".....and fly his rainbow flag.
Listen to what Lil R said...he is the Ftn rigging master...
I would also agree that you may be getting into some drive reliability issues with your semi-surfacing setup. A pair of XR's or SCX's may be in your future. Good luck and keep us posted.
C.I.M. 09-18-2011 04:47 PM
I can get my hands on a set of 32 maximus to try. Yes I did move the engines and drives. Glassed the transom, re cut the holes, modified the tailpipes, smoothed and painted the bilge ect. It was a big job but worth it. Thanks for the advise everyone.
Reggie Fountain 09-18-2011 08:50 PM
They might work, If I can help any message me your number & I will call you.
Reggie Fountain 09-18-2011 08:51 PM
