-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Finally some WOT numbers! (https://www.offshoreonly.com/forums/fountain/263920-finally-some-wot-numbers.html)
HOT_RODN99 10-13-2011 03:38 PM
Originally Posted by 47 lightning (Post 3526456)
did you try 5 1/2 on your drive trim thats what they like with that set up ,5 or 6 blades will not help you on top end with your curent drive set up. 2 or less on tabs.
I haven't tried 5.5 yet on the drive trims or 2 on the tabs. For the 84.5 speed, I had the drives at 4 and the tabs at 3. I will have to give that a go, hopefully this weekend. For the tabs though 3 is dead level with the bottom of the boat. Should I bring them up past neutral to make sure they aren't dragging at all??
As for 5 and 6 blades, do you think they only work better with short lowers, when the prop is more out of the water and surfaces more? If thats the case it looks like I'll have to try either hyrdo 4-blades, or labbed bravos.
How much will getting all that extra weight out of the boat including 1000 lbs less of gas in the tanks?
Thanks!
Yamaha 225 10-13-2011 05:25 PM
Thanks!
Hi there.. If your drives are low, I would not go with 5 or 6 blades. I tired Maximus 5 blades om my 29 Fever and it did NOT run good at all. It was porpoising and slow. If you have a 2 step hull, I would look for shorties. Abobe 80 mph, the drag becomes a critical factor.... I would lift the drives as high up as possible and run 6 blade herings with long hubs for max grip and steering. Then you will also get a nice rooster tail :-) Dont expect too much speed gain by replacing the props. They are usually the best and only 1-2 mph is possible to get with labbed props.
rgrgoog 10-13-2011 05:56 PM
Nice numbers so far. I am looking at shorties for my boat and I would think that would get you the most gain. I would try it with some labbed 32's. My boat runs the same right now with my labbed 30s vs my un-labbed 32's. I am getting the 32's labbed this winter and hopefully I should see some gain from it.
47 lightning 10-13-2011 06:12 PM
[QUOTE=HOT_RODN99;3526662]I haven't tried 5.5 yet on the drive trims or 2 on the tabs. For the 84.5 speed, I had the drives at 4 and the tabs at 3. I will have to give that a go, hopefully this weekend. For the tabs though 3 is dead level with the bottom of the boat. Should I bring them up past neutral to make sure they aren't dragging at all??
Thanks![/QUOT
my tabs don't do anything for me unless its rough out or to much weight on one side. triming up from 4 to 5 1/2 will gain you 300 to 400 rpm you will need labbed 32 or 31 which they make call teague.problem is youre props are worn and flex to much not thru pitch any more when you trim out you go no faster because you hit the rev limiter.
RaggedEdge 10-13-2011 06:38 PM
Originally Posted by HOT_RODN99 (Post 3525914)
So I think labbed bravo 32s would be the hot ticket to get to about 90-92. I also might try some 5B or 6B herings. I'm thinking those might get me to 92-94. Or what do ya'll think about those sets of props and those speeds?
Not to burst your bubble here but those speeds with 500's are a stretch regardless of props, IMO. 525's in your hull, better / higher X dimension, and I have an average of 90 or a little better most days in good conditions. Had a best of 94 with a set of 5 blades before the all knowing prop wizzards majic touch sent them down the chitter.
C.I.M. 10-13-2011 09:48 PM
My 2000 ran exactly the same with the stock set up. When your fuel guage reads 3/4 full you actually have less than half in the tank cause of the shape of them. Mine ran the same with one person and no fuel as it did full and 4 people. If I trimmed mine past 4.5 I would start slowing. Great numbers, sounds like your right where most of them in the early 2000's run.
HOT_RODN99 10-13-2011 10:11 PM
Our 35 is indeed a 2-step hull. Looks like I'll have to get my hands on some imco -2 lowers. And then couple those with hering 6B or 7B props. But for now I think labbed bravos will have to do.
Thanks! For my first weekend of a couple WOT runs, I was impressed especially knowing the boat was loaded down and that i didn't go very aggressive with the trim settings. I have 30" bravos unlabbed on it now, I think the first set of props I'm going to try will be 32" labbed bravos.
Oh really? Must be all 47' of boat out in front of those tabs. Haha. When I do take her out next, I'll try trimming the drives up to around 5.5 and see what happens. It should put it damn near the limiters or even on the limiters.
I know I was kind of stretching those numbers...I was kind of hoping if I said those numbers, that they would magically appear on the ole GPS! Haha. With a set of labbed 32" bravos and lots of shedded weight, do you think 90-91 is a stretch?
HOT_RODN99 10-13-2011 10:15 PM
Yea, I do remember hearing from one of the fountain mechanics that the bottoms of the tanks narrow up and that fuel level starts going down fast after 1/2 a tank. I haven't tried giving it more trim, so I guess time will tell. I think that when Reggie ran the 2001 twin step boats with 500 EFIs, they ran out at around 87-88.
PARADISE ISLAND 10-13-2011 10:22 PM
Nice speeds tabs up play aroung mark your sweet spot on the drive indicators!:drink:
HOT_RODN99 10-13-2011 10:27 PM
Thanks. Yep, its a gradual but fun learning curve with this boat! I hope to run it in the LOTO shootout next year. Except I'm not sure how they'd class the boat. Its stock, but I read on Capt Rons website that 500 hp isn't stock for some reason...WTF! Haha
