-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Toe in/Toe out (https://www.offshoreonly.com/forums/fountain/264113-toe-toe-out.html)
IRFever 10-15-2011 01:32 PM
Toe in/Toe out
I noticed that my drives are toed out. Should they be neutral? They're out by about a half inch if I measure at the front of the drive and at the prop shaft.
LicenseToChill 10-16-2011 10:58 AM
A 1/2" sounds like too much to me. I'm not 100% sure....... but if your props spin out, your drives should toe in. If your drives spin in, your drives should toe out. Which means that the distance between the prop shafts is more than the distance between the noses of the drives, level with the prop shaft. The toe in or out should be from 1/8" to 1/4".
Reggie Fountain 10-16-2011 12:11 PM
They Should Be Somewhere Between 1/16-1/8 Out Regardless Of The Prop Rotation.
LicenseToChill 10-16-2011 12:31 PM
I stand corrected....... Thanks Reggie :)
Boomer35 10-16-2011 12:41 PM
is that true for all boats? i always thought it was spin out, toe in.. and spin in, toe out
Reggie Fountain 10-16-2011 01:15 PM
Everything I Have Ran From Fountains,cigarettes,mtis & Skater It's Always This Way.
Marginmn 10-16-2011 03:57 PM
So the noses should be slightly closer than the prop shafts?
Reggie Fountain 10-16-2011 04:28 PM
Yes Sir.
Ran-Dom 32 10-16-2011 07:00 PM
would'nt that be toe "in" if you place your feet with your toes closer then your heels... isn't that how they came up with the name?
sooo... toe in 1/8 would be the optimal set up :grinser010:
Reggie Fountain 10-16-2011 07:14 PM
It Depends On How You Look At It. Toed In 1/16-1/8 In The Front Or Toed Out In The Back.
