-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Bimini top (https://www.offshoreonly.com/forums/fountain/269074-bimini-top.html)
mcprodesign 01-19-2012 07:07 PM
Bimini top
Tell me how horrible it looks
or maybe some Ideas???
It is 110 plus here in the summer so I have to have one.
I photochopped this. The local guy has a High speed ( stainless) top I can get for 350. It is dark navy blue.
Doesn't it look too short front to back. It is 6 feet long
tim brown 01-19-2012 07:58 PM
top
i have a 6 ft top on mine , I don't use it much because the wife doesn't like the shade . move it forward a little bit. I like them. I just cover the front seats .
SDFever 01-19-2012 10:24 PM
There isn't anyone that will make a better bimini than Paul Murphy. Period.
Westcoast 01-19-2012 10:56 PM
+1. Paul's doing mine
dewayne6243 01-20-2012 09:19 AM
Does Paul have to have the boat in person to make one?
Marginmn 01-20-2012 10:00 AM
Beats the heck out of heat stroke.
ROB FREEMAN 01-20-2012 11:19 AM
cant enjoy the boat if you cant ber in the heat , looks fine , i bet alot of boats with them in that heat !
Marginmn 01-20-2012 12:56 PM
1 Attachment(s)
Check out how much canvas I put on my Florida ride. It may not look as cool but it sure keep us cool under that wicked Florida sun.
97FASTech 01-20-2012 01:09 PM
No pictures of mine (yet). However I have a 6 ft top, but do not use the rigid poles on the back, I use the straps front and rear. This allows me to lay it flat during the high speed runs with no drag. Also I installed a track where it allows me to slide the top forward or backward, also when it is down I can slide it back over sunpad and then forward, in order to raise the pad to check oil. I also use quick release pins to remove altogether. I did buy rigid poles for the back support, just finalizing the way I want to mount so that it will flat, also with quick release pins. I meant to take pics last summer, but just too much of a hurry to hit the water, then forgot about the pics.
Marginmn 01-20-2012 01:33 PM
How fast can you run with it up?
J.B. Marshall 01-21-2012 07:22 AM
2 Attachment(s)
Not that it counts for much, but in my opinion it's one of the best additions we have on our 382. It provides great functionality benefits, gives us shade on those super hot days and the full bimini protects us during inclement weather when we are traveling and doing over nights. It was worth every penny & I would not go without one for the type of boating we do.
97FASTech 01-21-2012 11:21 AM
That just it. I don't ever run with it up. It goes up only when rafting or anchoring. I like WOT too much, too run with it up. After all, it does not take a whole lot of time to put up or down. My theory is if I'm moving with wind in the face, I'm staying cool enough.
mcprodesign 01-21-2012 11:23 AM
only mods to boat. 2 perches mounted on top the gunnel edge on the outside of the windshield. Then 4 Beautfil blue tie downs ( Lowes). No sturdy poles front or rear. Moving it up 1 foot. So It is 4.5 feet fron the sun deck. ( center point of top ) Probly be able to run 50 -60 w it up
When I want to go fast. Just un hook 4 tie downs, ( they will be sewed around poles or snapped) wrap them in the top. Simply install white bimini tube cover and trow whole unit back to the rear sun deck. Completley out of the way .
Top is all stainless tube designed for High speed by Eliminator.
Mine was brand new just stting there on his floor.( only used once before) $ 360.00 included the 2 perches.
This guy is right down the street and does work for Eliminator. His highest price is $ 750.00/ the base cost is 650.00..
http://bienzmarinecanvas.com/
Dkahnjob 01-21-2012 12:50 PM
Hi Chad,
That is a really cool looking boat. I agree, the Bimini top is a must have item for boating in So Cal and AZ. I had one like that on my old Fountain and have one on the Hallett too. the look ok and really make everything much more comfortable in the summer heat. You should be able to run 50-60 comfortably with it up.
Enjoy your new ride.
Dave
jackieboy 01-22-2012 09:22 AM
bimini
looks good, but i would move it forward a little
RICHARD CUNY 01-22-2012 10:11 AM
I get a littel heat from friends however if it is very hot I just put it on and fold it back and go, if I need its up in a snap. I have spent a lot of time under a bridge in the rain before mine.
Rich
97FASTech 06-19-2012 03:36 PM
Re-post with Pics
Maybe a little late:
I remembered to take pics of the top, however it is in the stow position. It will slide forward and backward up to three feet. I have a 6 ft top, but do not use the rigid poles on the back, I use the straps front and rear. This allows me to lay it flat during the high speed runs with no drag. Also I installed a track where it allows me to slide the top forward or backward, also when it is down I can slide it back over sunpad and then forward, in order to raise the pad to check oil. I also use quick release pins to remove altogether. I did buy rigid poles for the back support, just finalizing the way I want to mount so that it will flat, also with quick release pins. I meant to take pics last summer, but just too much of a hurry to hit the water, then forgot about the pics.
pullmytrigger 06-24-2012 02:36 PM
1 Attachment(s)
not a great pic but here's ours with the top up.... if I was to do it again I would go aluminum. With the stainless the thing is HEAVY and I NEVER run with it up so it doesnt need to be able to withstand a run at speed.
mcprodesign 06-24-2012 05:53 PM
looks good! I had an aluminum one before. And just bareley on plane it got dificult when the high winds hit.. fyi ;)
acaruso 06-24-2012 06:12 PM
:eekdrop:getgray or white i have a blue one ) it is verry hot to the tuch
mcprodesign 06-25-2012 01:42 PM
Dark colors provide more uv protection
soldier4402 06-26-2012 07:23 AM
Dark colors may fade quicker though.
I would never ride with a bimini top up and have thought about pulling the trigger on this http://www.boatersland.com/tayashade.html
saw one on a 35 and guy said it worked great. Plus it should be easier to store.
FREAKY FAST 06-26-2012 09:16 AM
You have to do what you have to do! I had a aliminum framed, green top on my older fountain. it was low profile and looked pretty good. We could cruise with it all day. 50 mph is as fast as I would push it but ur for sure not going to be doing any WOT passes. Go ahead and get it! Can always take it down on cooler days!
