Hatch Switch?
I have a 98 29' fever. My engine hatch switch quit working because it lost its ground. When I hook a ground from another switch it works fine. So before I run another ground to the motor, does anyone know where the current ground is?? Thanks for any help.
I just swapped the dash and switch plate on my 98 32', the grounds from the switch panel were on 2 seperate terminals connected together behind the dash. There was also a couple of bullet connectors 1 behind the switch plate and 1 in the main harness, may of come loose or corroded.
Originally Posted by JoCo32
(Post 3643109)
The engine block is grounded. Or where the negative battery wires connect to the starter.
Originally Posted by FREAKY FAST
(Post 3646018)
| All times are GMT -5. The time now is 12:43 AM. |
