bolster seat problem
My bolster seats were working fine before i put my 1995 27 fever away for the winter.Now comes spring and there is no power at all.I checked the fuses under the dash and the circuit breakers.Any suggestions would be greatly appreciated.
double check your breakers, and fuses, I would bet it's one of those.
Fuse up under the dash, or take the terminals apart on the switch & sand them down!
sounds like its the switch its self or the wire's coming from fuse or breaker to switch are open.
If fuses haven't shown anything put a meter on the connections from the seat auger motor and work your way back. Sooner or later you will find the break in power. I hate electrical problems. Good Luck
Luckily there shouldn't be to much in that curcuit, the fast both bolster are not working lead me to believe its and open fuse or breaker. Meter the fuse for continuety.... I've had fuses open that looked fine.
check all connections, sand them down and diaelectric grease. Follow all the wire to make sure there isnt any breaks. If not might need a new pump, quick fix but new pumps are like 400 bucks.
Mine wasnt working either ended up being a leak in the resovoir, replaced and that works fine. I didnt even know it was leaking all the fluid would drain into the lower bilge because of how the boat sits and then just went out when I open the hole. Never knew it was leaking. |
| All times are GMT -5. The time now is 05:48 PM. |
