-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   What's the secret to keeping swim ladder covers on these things (https://www.offshoreonly.com/forums/fountain/275735-whats-secret-keeping-swim-ladder-covers-these-things.html)
mcprodesign 05-03-2012 12:58 PM
Mine seems to loosen uip regularly from the pounding it takes. I am afraid if I reglass it I won't be gaining anything but a couple weekends til it vibirates apart again. Anyone got a plan?
1 MAIDEN AMERICA 05-03-2012 04:58 PM
That's my next project. I'm thinking of repairing the screw holes and using 5200.
C.I.M. 05-03-2012 10:17 PM
I used 3M Automix 8115 panel bond on each screw and it has never come loose again.
Interceptor 05-04-2012 12:31 PM
Just went out and looked at mine. There's 20 screws fastening the piano hinge and none of them are loose. This is on a 1996 hull so guessing some adhesive like the others suggested would help. Same for the latches.
ed
snapcracklepop 05-05-2012 09:41 AM
ed
I changed the way the hinge was screwed to the lid because the screws had nothing to bite into. I cut a slot in the side of the door and inserted the hinge then I drilled holes from the hinge through the top and inserted small bolts with nuts on the bottom side under the hinge. The small bolts ( 4/40) I think are much stronger and look fine.
mcprodesign 05-05-2012 10:24 AM
you are my hero:cool-smiley-026:
mcprodesign 05-24-2012 01:19 PM
I wanna thank the board and Snapckracklepop for inspirining me to do something good to my boat. I can do this for anyone. It will cost more for the carbon fiber. I'm Not trying to take work from anybody . just looking to help out :D.
I don't think this will fly off in the future. My boat pounds hard on the swim deck at Idle. Here is some before, after and progress I am doing today..
mcprodesign 05-24-2012 01:58 PM
Here you can see I have retained all the original gel coat on the outside. Also the original hole locations are intact. The outside you are looking at just has the dirt that was in between the hinge and the cover. Once that is cleaned up and buffed out, you will not be able to tell because I retianed all the original exterior Gelcoat
snapcracklepop 05-25-2012 10:34 AM
Glad it worked out for you. Mine has been fine for a year.
