-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   32 fever or 35 lightning (https://www.offshoreonly.com/forums/fountain/280086-32-fever-35-lightning.html)
fastlife 07-06-2012 12:09 AM
so i am hearing mixed reviews here and maybe some of you guys can clarify it up a 1994 35 lightning old school non stepped hull is a better boat than a 1995 stepped 32 fever in the chop and the ride quality is better in which boat also the cockpit area is about the same size or a huge sizeable difference between the two? whats the pros and cons and which one would you rather have
jmoore1225 07-06-2012 12:29 AM
32 will be faster by a few mph, the 35 will have a few more inches between the bolsters & back bench.... The majority of the added room is under the hatch & is very, very helpful if you plan on doing your own maintenance. Also very noticeable difference in the ride quality,not that 32 rides poor it's just a nice difference!!!
Wildman_grafix 07-06-2012 12:05 PM
IMO
Somewhere in hell Lucifer is making a guy work in the engine compartment on one for eternity.
Which is exactly what it felt like last weekend in FL working on mine.
dykstra 07-06-2012 09:37 PM
I'd rather have the 35.
29scarab10 07-06-2012 10:23 PM
on the 32 you will have to crawl over the windshield or go out the hatch to tie up or use front anchor. The walkway on the 35 makes life alot easier.
jmoore1225 07-06-2012 11:08 PM
Originally Posted by Wildman_grafix (Post 3724555)
IMO
Amen to this!!!!
tim brown 07-09-2012 01:56 PM
go with the 35 bigger is better. I could be bought .
malo29 07-10-2012 06:49 PM
shoot me a pm i already bought one from you it turned out well and i just sent it to ny. looking for a 35
Carder 07-10-2012 06:58 PM
No question on the 35... 32 has the same cockpit as the 29, and not near the ride in the waves.
Carder
dykstra 07-10-2012 11:15 PM
Carder
32' has the same cockpit as a 27' and 29'w/twins.
sonickevin95 07-11-2012 08:36 PM
Both great boats, I was torn between both. Dont regret going bigger in a year from now like we all have done before. Both fast hulls, both great looks, and if engine bay tightness is an issue then STAY THE HELL OUT OF BOATING!!! because I have yet to be in a comfortable enine compartment yet!!!
gofastlvr 07-11-2012 08:44 PM
Both engine compartments are made for Umpa Loompas so don't let that decide for you... the 35 definately rides better and I would doubt the 32 is faster as the stepped bottom gains are noticeable. If you buy the 32 you will wish you bought the 35 and if you buy the 35 you will wish it was a 38... buy the 38 and you will REALLY wish it was a 42 etc... I have had a 35 and a 42 so I have a little experience so buy all you can afford and then borrow another 15k because you will be glad you did!
PARADISE ISLAND 07-11-2012 09:23 PM
35
Beak Boater 07-11-2012 10:01 PM
Owned a 2000 32, and a 2000 35. I know, not apples to apples, but......
Our 32 had 500 hp, carb motors ran 83 mph. Boat handled ok, had a tendancy to not fly level and landed stern first, if you ever lauched it by accident. Cockpit on 32 was just a little bigger than our 27. Cabin was a bit larger and taller.
No walk around on deck, as said, if you do anchor, you will find yourself dropping the anchor over the side of the cocpit and tying it off the side cleat, instead of stepping on the passenger handle and climbing over the windshield to tie off on the bow cleat. Same when tying up to a dock.
32 had what was to me an annoying problem. When idleing out of the marina, the exhaust would get trapped under the swim platform, because the stern set so low, and cause vibrations that would shake the boat. We had silent choice, and if I used that it was not as bad.
35 had 500 efi's and ran 88 mph on liquid filled speedo. Walk around made anchoring, and trying up much more manageable, boat flew level when launched. The 35 rode better in rougher water seemed to be better balanced. Cabin on 35 was bigger than the 32. 2000 was the year they came out with the Lightning model, and the cockpit was redesigned, so its not really fair to compare them to the boats you are looking at.
Over all I liked both boats, both ran great. My choice would be the 35 over the 32.
