fuel flow issues/ fuel pressure on 500efi
hey guys, Does anybody know know what normal fuel rail pressure would be on a 500efi hp, with the coil wire removed, cranking the motor out of the water with no fire? I'm getting 10-12 psi on my gauge. The reason I'm asking is my fuel system is not pumping enough gas to the engine at idle and throttle back trolling. I thought I had found the problem with the original mechanical fuel pump not pumping gas out the top when cranking the motor. Replaced that, and still had the same condition. Thinking that I had more issies back towards the tank, I was told to look for an anti siphon valve and see what that looked like. Tonight I tore into that, and found that there is no screen, or anti siphon valve on the top side of the gas tank. At this point I have no other ideas. |
Have you put a mechanical gauge on the schrader valve to see what it is doing? The electric senders are often not accurate.
Originally Posted by triple 300s
(Post 3731611)
thinking your looking for a new fuel pump my man should be in the 40's if i remember correct i replaced one of mine last fall
Originally Posted by mikesystem01
(Post 3731854)
has anyone ever heard of the collar on that cam shaft that runs the mechanical fuel pump wearing out? anyone have any other ideas?
it wouldnt be wore out unless the arm that runs the mechanical fuel pump was destroyed, dont ask how i know lol
Not to go off topic... but 500EFIs have mechanical pumps? Mine doesn't???
Originally Posted by Jpzaluski
(Post 3732518)
(Post 3732525)
You should have one down off the impeller housing...no?
| All times are GMT -5. The time now is 10:40 AM. |
