-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   38s, drive heights? (https://www.offshoreonly.com/forums/fountain/281936-38s-drive-heights.html)
prostockcat 08-01-2012 08:17 PM
38s, drive heights?
got a 38 fever stepped. put -2 shorties and the boat will not carry the bow got 5 blade hydro 30s on it spinning 5200. saw 82gps did the shorties make this boat slower? what has worked for you guys with similiar 38ft boats with around 600-650hp thanks
575cat 08-01-2012 09:07 PM
I believe maximus props would be better .
mcprodesign 08-03-2012 12:53 PM
I like the Maximus and I'm glad I have them. They are always locked solid any any RPM and they plane well.
I have a set of 5 Bl Herings headed my way. I'll let you know if they are better for top end and how they make the boat plain . Once you raise your props out of the water a bit the p5x's won't work.
Chad
prostockcat 08-03-2012 06:25 PM
man i called hydro and they said because of what i did with the drive height my prop slip was way high so i need 5blades. i had 30 B1s and hit about 83-84 but was revving 57-5800 (a little to high on the revs) so i spent like 2200 on these props for nothing. i love boating!!lol
Roger 08-03-2012 06:57 PM
5 blades will probably work better, but remember if you try to carry the bow too high you will be working against the forward push. Our boat ran better with drives parallel and letting the bottom design work its magic. If it bow steers then it definately needs more bow lift.
MILD THUNDER 08-03-2012 07:17 PM
How far below the bottom are the propshafts now?? I'd try some Maximus props.
prostockcat 08-04-2012 05:14 AM
3.5 -4in propshaft
Esquire 08-04-2012 06:28 AM
Which Hydromotives did you get, the P5X (round ear) or P5 (pointed, cleaver style ear)? The P5X provides more bow lift. As others have mentioned, I have found the Maximus to be a better all around prop than the Hydromotives. Better planning, cruise, handling, and top end. That said, at your current prop shaft height, I don't think 5 blades are what you need. I would try to find a pair of 32 Bravo 1's. They should drop your rpms by 300-400 turns as compared to the 30 Bravos. Labbing with get you back a couple hundred rpms.
Better yet, I would give Brett at BBlades a call. He has most brand props in stock, and his prop exchange program would have saved you the $2200 you spent figuring out the Hydromotives are not what you need.
Also, the 38' Fever runs high 70s, maybe 80mph on its best day with Merc 500hp's. So with 600-650hp, I think you're doing good at anything over 85mph.
MILD THUNDER 08-04-2012 09:05 AM
I agree with the above post. If your props are 3.5-4" below th running surface, you don't need a 5 blade. With your power you are doing ok. Depending on what your dyno sheet shows, a little higher rpm can help save your drives.
mcprodesign 08-04-2012 11:46 AM
Originally Posted by prostockcat (Post 3745640)
3.5 -4in propshaft
px5 round ears should work at the depth . Do you have the port prop spinning clock wise and the stareboard prop spinning counter clockwise?
prostockcat 08-04-2012 02:36 PM
p5x is what i have and the props are spinning in
mcprodesign 08-04-2012 03:54 PM
Every time you add a blade the back of the boat will come up higher. I say. Call hydro.. - stocking fee , you should get a refund. Sounds like your boat worked well with the Bravo 4 bl ( which is not uncomon because that is what your boat was designed for) Now is a good time to sell props in the classifieds. Not at the end of,the season. You should be able to get close to what you have in them on the oso classifieds. I say 32 B 1's. BBlades.com will rent you a set for 25 bucks a piece. If you like them you can just buy them off him. Hope this helps. Chad
mcprodesign 08-04-2012 04:02 PM
32'S First..You might be able to swing labbed 34s. But the labbing is more time and $. I personally am trying everything stock first before I commit to labbed.
prostockcat 08-04-2012 06:42 PM
thanks for all the help
47 lightning 08-04-2012 10:22 PM
i had a 97 38 fever great rough water boat.it needed at least 5.5 trim to fly.3.5 or 4 below bottom is still deep in the water in fact when i put - 2 shorties on my 47 i gained nothing .hydromotive Q 4 is what that boat came with and they work great on early model fountains.
racinfever 08-05-2012 09:23 PM
I have the same boat as you with -2 imco lowers, you are maybe over triming the short gear cases. I only trim to 4
with bravo style props. My boat ran 86mph with 600 hp aside, 92mph with T 700s & 105 with T850.
prostockcat 08-06-2012 07:50 PM
u talkin regular b1 props?
racinfever 08-06-2012 09:59 PM
Stock bravo1 or q4x hydro work best with big motors.
CayFomula 08-20-2012 09:31 AM
I have a 97 38' Fever with XR uppers and Imco -2" shorties, for power it has Mercruiser HP500s with Dart Pro1 CNC heads, cam, Stainless Marine Gen 3 exhaust and carbureted Whipple 2.3L Superchargers I figure I'm making about 700-725hp at 6lbs boost. With BBlades 32p Bravo1 props it ran 97.4 mph at 5800rpm with 2 people and about 150 gal fuel with minimal trim about 4 on the indicator.
It is possible the motors are putting out a bit more but not much given the small SC but i live in the Cayman Islands and dont have access to a dyno. I am reluctant to say this because some people might doubt me but the truth is that wasn't top speed, it was in a poker run and I was holding back a small pinch or throttle and she definitely runs faster with more trim but I was holding back till later, unfortunately engine mashed up before I got to go for broke.
prostockcat 08-20-2012 01:46 PM
GONNA TRY SOME STOCK b1 32S AND SEE WHAT HAPPENS
