-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Sand! (https://www.offshoreonly.com/forums/fountain/282188-sand.html)
maineriverrunner 08-07-2012 07:46 PM
Originally Posted by maine27 (Post 3748562)
ya its there now hes gona check the pump and inpeller and the whole system thank for the help.
Let us know how you make out. I may still be chasing a pressure issue aswell....
maine27 08-09-2012 05:32 PM
Just got it back there was sand in the system witch i new pump and inpeller was fine backf;ushed everything still only have bout 12 lbs at 4000 rpm it pumps water fine and is not overheating i just dont get it.
maineriverrunner 08-11-2012 07:39 AM
Backflushed mine entirely the other night, no sand. Flushed back through the drive and all pickups, not plugged. Gauge line had nothing in it. Had a different gaffrig water pressure gauge. Installed it. Can't see what would be wrong with a mechanical gauge, but for lack of a better idea at this point...The weird thing is I used to have 35psi at WOT. I'm going out tomaro, Sunday, weather permiting. I'll let you know what happens, sounds like we have the same issue, and have approached the fix the same ways with no luck.
maine27 08-11-2012 08:19 AM
IM gona change thermostst today i think its stuck open we will see what happens.
