-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Need help with gauges not working (https://www.offshoreonly.com/forums/fountain/283332-need-help-gauges-not-working.html)
Interceptor 09-05-2012 09:57 AM
Originally Posted by Lucky1456 (Post 3769411)
Guys Im haveing a simular problem. The problem I have is only with one guage. I changed my oil temp guage. It was a gaffrig guage before and I bought a Livorsi guage to replace it with. This guage is an oil temp guage. I put on the Livorsi guage exacley like the gaffrig guage was hooked up and nothing at all. In fact the guage is pined down on the left side and has not moved since I hooked it up. I bought the new sending unit too but I can get my hand on the sender to change it. Do you think the two guages hook up different?? I did notice the light inside of each ic different. Let me know your thought's
Similar problem here, Where is your oil temp. sending unit located on the engine ?
ed
Lucky1456 09-05-2012 10:45 PM
Thank You sir I will do that and see what happens. Do you know where the oil temp sender is located? It seems someone told me it is around the oil filter.
rw40426 09-05-2012 11:00 PM
If you have a 525efi, I can tell you where its located?
