Did you pull the bed pad up & look under it in the storage compartments under it for water? Like you said maybe its just now finding its way back to the step since it is being used.
Originally Posted by jmoore1225
(Post 3773740)
(Post 3773740)
John jr |
I know on my boat to get water to run back sitting on the trailer you have to really have the tongue way up, or it'd just sit up under the bed from the bow rails & front light. My bow rails leak but you wouldnt know it unless you actually caught ir running in from the rails posts. Bow hatch is also a bad leaker!! just always make sure to have a full cover on it if you don't. Best investment I have made.
My boat sometimes get water trapped in the stepped area of the hull, it comes forward when on the trailer. I agree with what is written above, try to get it high when on land. Any water from the firewall? back seat forward will drain to that area. I left the scum line on my boat once after a weekend of boating. Got home and taped a level to the side of the boat in the back and tried to match the way the boat sits in the water, ran out of trailer jack and it was scary near the tounge.
You could always park it uphill? :D |
Hi. I have experienced a water leak from the anchor locker on a few Fountains. Go inside the cabin and at the very front of the bed matress. Forld it upwards and see if the carpet is wet against the mirror. This is a wooden playwood plate that is glassed to the hull and deck. This fibre glass is not always watertight. There use to be some water in the anchor locker as the drain hole is not at the locker's absolute bottom. Try that and post the result here!! If it is wet, then remove the morror and 5200r on both sides. If there is a bracket on the "floor" of the anchor locker, remove it and see if there is water there. I found 3 gals of fresh water on a 2007 35 ICBM on time!!
Originally Posted by Yamaha 225
(Post 3794257)
same here, the anchor drains actually work now!
(Post 3794257)
| All times are GMT -5. The time now is 03:05 AM. |
