-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Why so few Imco -3s? (https://www.offshoreonly.com/forums/fountain/286566-why-so-few-imco-3s.html)
Jpzaluski 10-18-2012 10:55 AM
I'm planning on putting shorties on my 2000 38' Lightning this winter, and it seems that the standard is -2s. My boat is rigged extremely deem in comparison to the latest models, so I definitely don't feel moving up 3" is excessive. Do people shy away from them just because of the mods necessary to the upper, or are there other reasons?
keegan 10-18-2012 01:16 PM
good question. I am curious also. I swear my drives are 6' under the water lol...
mcprodesign 10-18-2012 01:42 PM
W my -2's; 15 5/8 Dia Props fit but it is close.. W a -3 you would need to run smaller diameter props if you are using bravo uppers.. ;) If you want to get on plane w a high X, bigger seems to be better. I sent you a fb friend request just now
mcprodesign 10-18-2012 01:59 PM
I will also add.. If you have a super deep X , a small set of props might be faster and have no problenm getting on plane, so the -3 might be good. But no one knows where your propshafts are in relation to the bottom, but you .
TRL505 10-18-2012 02:52 PM
Sharkies....
DiamondPerformance 10-18-2012 03:52 PM
Biggest prop you can run is a 14" 3/4 diameter with a -3 lower and Bravo 1 upper. If you buy a complete (upper & lower) Imco -3 drive you can spin 15"7/8
Griswald 10-18-2012 04:02 PM
unless you get the saw out :party-smiley-004:
Jpzaluski 10-18-2012 07:21 PM
but if I notch the upper to run bigger wheels there is no plausible disadvantage at that point?
mcprodesign 10-18-2012 08:02 PM
The drive will no longer accept the stock lower. And it may look a little stranger that chopped off. I looked into it when I was putting mine on. But like I said you could probably go faster with small props if your ex is low
Back4More 10-19-2012 05:35 PM
How many blade prop you looking to run?
