Air Unit
Old 05-12-2016 | 02:05 PM
Originally Posted by nailit
MT/4bus:
Did y'all ever install the portable a/c? I was thinking the same thing.. Pull from casing and mount under sink. Access to gunall for hot air and sink drain for water. Would are you running the unit on?? Inverter. If so how many watts needed?.
Wondering the same thing
nate2587 is offline
Old 05-12-2016 | 03:10 PM
MT/4bus:
I ended up installing a mermaid 6000btu reverse cycle unit in the cabinet where cooler was. Best thing i did since owned the boat. Quiet, cold, and plug in to shorepower and thats it.
MILD THUNDER is offline
