Rear side rails and docking lights wanted.
Since my boat had an arch when I purchased it, the rear rails were removed. Any one have a set that will work on a 32 fever? Also looking for a set of the factory docking lights. Mine work fine but are cracking badly. Thanks in advance.
Can't help you out on parts, but your 32 had an arch? Never seen that.
Originally Posted by US1 Fountain
(Post 3870662)
Btw, I just need the docking light covers and not the entire setup. |
I bought a 97, 35 lightning late last fall. The docking light lens were cracked and I contacted Fountain to see if I could get the lens. They told me that the only thing they had was the complete unit. Gail told me to check with www.barnegatlt.com. They had the housing for 84.00 each. Could not get just the lens cause it is a 1 piece molded assembly. I called barnegat and they told me what I had to have. I do not know if yours are like mine or not but I thought I would let you know what I had to get.
Originally Posted by speedfever
(Post 3870988)
These are exactly what I have. $427 online http://www.lightinguniverse.com/mari...kLoc=quickView |
That is what I have. That is the whole light assembly. All you need is the housing. My invoice from Barnegat says, "description" QL-32 white with lens. "Item number" 8010-000-140
$89.22 each Call them to verify your needs. |
| All times are GMT -5. The time now is 08:54 AM. |
