cabin lights
cabin lights in my 38 fever work but when u shut them off with the manual button they will not come on. these are the flourescent lights around the ceiling. is they a way to bypass the manual switch on the side of the light so they just work with the single switch for all of them?
You can pull the switch and just wire the two wires together.
Why not just leave the switch on each lite in the on position and just use the toggle switch to turn them all on/off?
thats what i want to do. i am resealing the bow rails and had the lights on as i was removing the bolts. on 4 of them i accidently bumped the the switch with my arm and shut them off. now 3 of the the 4 it happened to will not turn back on??
Did you try moving the bulbs around to the one that works to see if the bulb was bad?
Why dont u jus chit can the factory lites and go to supprebriteleds and get a new lite.have a replacement for that lite for less than 20.00
sounds good thanks
| All times are GMT -5. The time now is 10:24 PM. |
