-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   No Power too trim pump (https://www.offshoreonly.com/forums/fountain/296289-no-power-too-trim-pump.html)
FOUNTAIN TURBO 05-13-2013 06:43 PM
My power trim pump is not working I have no power too main wire that goes too the solenoid any ideas?
tomtbone1993 05-13-2013 07:04 PM
Have you checked the breakers under the rear seat?
FOUNTAIN TURBO 05-13-2013 07:37 PM
I am trying too find replacements for them they are very rusty and had some kind of rubber coating on them
tomtbone1993 05-13-2013 07:41 PM
It's a generic breaker, you can find them at west marine. You may try to bypass the breaker to see if it fixes your issue.
CraneHillFast 05-13-2013 08:12 PM
I've had the same issue with the breaker. But all i had to do is reset. For some reason the only time it happens is when it sits up for the winter???? Hit the breaker and its fixed...
tomtbone1993 05-13-2013 08:13 PM
Good point, might be easier than my suggestion :)
FOUNTAIN TURBO 05-13-2013 08:19 PM
How do you reset them? Mine did the same after sitting all winter have already replaced solenoids guess new stuff dont hurt lol
tomtbone1993 05-13-2013 08:26 PM
Hit the breaker with some wd40 and push the button in. May be red or black, may slide in.
FOUNTAIN TURBO 05-13-2013 09:21 PM
There are no buttons on these may have rusted off lol think I will just replace them thanks for the help just another hurdle with this project
txtraveller2002 05-14-2013 12:24 AM
make sure your fluid resivoir is topped off. Mine tripped when it got low.
soldier4402 05-14-2013 07:21 AM
ive always wondered what fluid to use. I have been thinking about sucking it out and replacing it. But cant figure out the correct fluid.
badluck 05-14-2013 07:48 AM
You can get generic breakers from Summit.
CraneHillFast 05-14-2013 08:04 AM
Win you find the fix or replacement, will you PM me the part number of where you find it. Mine aren't bad but i figured it might be a good part to have a few of on hand in case mine were to lock up as well. An easy fix can ruin your weekend if you don't have the $10 part to fix it.
