-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   fountain 2005 lightning trim tab cables and rocker switch (https://www.offshoreonly.com/forums/fountain/296476-fountain-2005-lightning-trim-tab-cables-rocker-switch.html)
elmoooo 05-16-2013 07:24 PM
Where can I get new rocker switch for trim tab on my 2005 lightning and my cables for the trim gages are jamed
dewayne6243 05-16-2013 10:10 PM
Who have you called already?
38fountainecman 05-17-2013 08:08 AM
I recently redid a Formula (should use the same trim rocker switches and trim indicator cables). I ordered Teleflex Extreme C33 black cables off of e-bay. I think these new extreme cables use carbon fiber, not stainless, so they don't rust like the red 33C cables found in most of the older boats. You'll need to remove the cables you have, measure them and order new ones accordingly. As far as the trim switches, I think Fountain uses Bennett rocker switches, you can order them from CP Performance or KE Performance Products. I've been trying to find the new chrome plated rocker switches, they look pretty trick on a Formula a guy just re-did the dash, black dash, chrome guages, switches, etc. Good luck
elmoooo 05-19-2013 09:18 AM
Thanks38fountainecman for the info ill check it out
