-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   bushings for fountain bolster seats (https://www.offshoreonly.com/forums/fountain/296897-bushings-fountain-bolster-seats.html)
bcfountain 05-23-2013 01:53 PM
after 750hrs on my 1994 27 fever the bushings in the bolster seats have failed.does anybody know where i can locate them?took the bottom part of the seat out last nite.some of the bushings are useable.but most are trashed.any ideas?thanks.
Lofty 05-23-2013 04:14 PM
McMaster Carr sells them. I've found that some fit off the shelf and others will need to be turned down to length very slightly.
Here: McMaster-Carr
Langston 05-23-2013 08:08 PM
I got some from Fountain a couple of years ago, shoulder bolts, bushings, washers, there's a combination of different size stuff as I recall. all fit perfect. I've got an invoice with the part #'s if you need them, I sent Gail an email then with pics of the stuff I needed. but there's a new crew in there now. I've been trying to get a fuel sending unit for a few weeks now and I still don't have anything that's even close to right. I finally gave up. I have a sender here from Fountain that's fits something though............
bcfountain 05-24-2013 08:26 AM
the problem now is the nut that is welded to the frame that the shoulder bold screws into is broken lose.short of tacking the whole seat out to reweld ,i dont know what else to do.
