2006ish owners...need help. Fuel tank ?
Guys is there a cross over valve somewhere in the boat for left and right tanks? Or are they specific to each side? Need to find that valve if so..where is it?
Has separate tanks for each engine, makes fueling up a pain in the azz
One tank one engine, there are fuel shut off valves in the bilge for each tank, should be on the outside stringers, least mine are.
Found those. So no other valve to marry the tanks or just suck from one?
Nope, not on a Fountain... or an MTI for that matter! lol
Originally Posted by gofastlvr
(Post 3934161)
Originally Posted by mcprodesign
(Post 3934357)
knda weid thing my starboard motor always uses more fuel than the port motor. Maybe cause i always start that one first
And FYI Viper chad, 1/4 tank is about 10 gallons, 1/8 of a tank means you have about 30 more seconds of run time. I have tried adjusting the sending units, the shape of the tanks are the culprit. |
Originally Posted by 4bus
(Post 3934437)
Mine is the same way, sometimes up to 7 gallons at fill up. I am thinking that motor is working a little harder. Personally I don't care that they are not linked, never seems to be an issue.
My fill ups are 2 to 5 gallons different. A couple years ago it creeped up and eventually hit 9+ gallons different so I sent the injectors in. One would go full flow above idle. I replaced it and cleaned the others and now I'm back to 2-5 gallons different at fill up.
Steering wheel looks sweet. The first things I changed were the wheel and cup holders. I see you're holding out on the cup holders. What's with the original white wheels? Maybe in a 71 Camaro but not my boat. Headed out boating in a few. It's supposed to hit 67F lol |
Originally Posted by 1 MAIDEN AMERICA
(Post 3935081)
| All times are GMT -5. The time now is 09:33 AM. |
