-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Adjusting Drive Indicators (https://www.offshoreonly.com/forums/fountain/297735-adjusting-drive-indicators.html)
breakitout 06-10-2013 11:47 AM
Replace your anodes! :hijack:
Wes Burmark 06-10-2013 05:00 PM
Breakitout - I did that task next.
fhebert 03-25-2020 09:00 PM
Where did you buy the cable?
QUOTE=Wes Burmark;3939692]Ford F350 - When I first got my Fountain in 2011 the port drive indicator had "limited range" just as you described. I too, took apart the cylinder thinking that it could be the reason the indicator would not travel its full range. The cylinder was not the issue. I had to replace the cable.
There were two different qualities of cables with the top quality costing only about $5 more. I had the cable replaced (about a $50 item) and the indicator worked perfectly. The starboard cable lasted a year longer. Now I just need to get the indicator dialed in which appears to be an easy process thanks
to the knowledge of folks on this forum -:) Good luck.[/QUOTE]
