29 Fever cabin lights quit working
Cabin lights quit working (both direct and indirect lights), they worked fine the day before. With the cabin power switch on the radio and the water pump for the sink come on but not the lights? I checked all the fuses under sink, under the dash and circuit breakers under the rear seat. I haven't checked for power behind the switch in the cabin yet but maybe I'm missing something. Any help would be appreciated thanks.
simple things first, try new bulbs. the star at the switch with a volt meter. If the switch is fine, you got bad bulbs or wire came loose. I would bet a loose wire.
Check those breakers closely. It isn't noticeable when they are popped. I found this out the hard way with a drive solenoid.
Originally Posted by TC G
(Post 3946306)
| All times are GMT -5. The time now is 01:07 AM. |
