-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   38 Express Cruiser leaning right or left issue (https://www.offshoreonly.com/forums/fountain/300366-38-express-cruiser-leaning-right-left-issue.html)
flat rate 08-26-2021 12:32 PM
I have one also. It’s just a learning curve trimming it. Run the tabs at 4 and it will help
George k 08-26-2021 01:13 PM
Thank you, found the forward hulls to be full of water, I had to pass on the boat.
victorketch 02-18-2022 09:20 PM
water in foward hull. 06 fountain ec new owner
can you please explainin detail how to see if there is wster in forward hull?
joet13 02-24-2022 08:20 PM
Water in forward hull in 38’ EC
Victor, When i bought my 38 EC in 2016 it did seem to have more of a leaning problem. there is a small hatch right under the stairs where you can access the middle bilge. I replaced both an open bilge pump as well as the shower sump and pump located in the same location. If i remember correctly, the shower sump handled both the shower grey water as well as the drain hose for the A/C that was located under the bed. If neither of these pumps are working you will accumulate water in the middle/forward bilge. When not working, I was very surprised how much water the A/C made.
after driving a few years, I never even noticed the lean, maybe because of replacing the pumps and probably some attributed to “driving” the boat, as wind will certainly affect the lean, and sometimes small helm adjustments would straighten it, if not then a little tab action. I never ran the boat with tabs fully up, always as least at neutral to effectively lengthen the hull, which certainly helped with the lean.
Hope this helps.
