-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Draggin' A$$ (https://www.offshoreonly.com/forums/fountain/301056-draggin-%24%24.html)
Jpzaluski 08-07-2013 06:17 PM
Draggin' A$$
I've begun to notice my 2000 Lightning pushes out one hell of a wake compared to most other boats. My friends 04 Ex and 08 Lightning I see run commonly don't have a tendency to do this nearly as bad. Even WOT my boat seems to be stern hard in the water regardless of trim or tab assistance I've run props ranging from 28-32 Bravos and 5 blades as well with little to no change. Brett @ BBlades suggested I try spinning the props out to get some stern lift. Has anyone ever experienced this? Anyone ever tried props out on our boats? Is this just the way a small step/side by side runs?
Back4More 08-07-2013 06:45 PM
The other 2 you mentioned are staggers right? its good to carry the bow out of the water, its not porpoising right? You can try spinning them out but i think you will loose top end.
Are your 500's stock and how fast is it now? Should be a 90 mph boat.
Jpzaluski 08-08-2013 05:45 AM
The '08 I referenced is a full stagger and that I can understand the difference, the '04 is a side by side Ex. My motors are stock and in good shape.... but no where near 90. More like 80
mcprodesign 08-08-2013 12:59 PM
maybe 90 w 575's but not w 500's
Coolerman 08-08-2013 01:11 PM
I would agree with BBlades that trying them spinning out is at least worth a shot.
tnt1 08-08-2013 05:13 PM
if anything its the other way around guys are trying to get more bow lift from running higher drives and 5-6 blade props that's where high rake props help how deep are your drives and what rake props are you running
Marginmn 08-08-2013 10:14 PM
If you still have the original X-dimension that the boat came from the factory with in 2000 then that is your answer/problem right there. I had a 2000 38 Fever and I came up more than 2 inches from the original X and it really made a difference in both speed and the attitude of the boat when on plane. The factory said I could have come up even more with today's prop technology vs what they had in 2000. The downside is that it's harder on the drives.
POWERPLAY J 08-08-2013 10:40 PM
Correct me if I am wrong but spinning in increases transom lift? Any of my Fountain friends spin in using Hydromotives with great results.
