-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   building power for my 10 meter prop help (https://www.offshoreonly.com/forums/fountain/305561-building-power-my-10-meter-prop-help.html)
indypromarine 11-20-2013 04:04 PM
i am building power for my 1985 10 meter
new power will be 575 hp with trs drives and hubber trans
boat ran low 70 with 440 hp stock with 25p 3 blades
any one have good idea on what p prop to run with new power ?
Griswald 11-20-2013 04:18 PM
A good friend of mine owns an '85 10 Meter as well with approx 550hp on each side. He swings 26p Hydros and the boat seems to like them a lot.
indypromarine 11-20-2013 04:25 PM
what kind of mph is he doing ?
Griswald 11-20-2013 05:21 PM
77-80 depending on conditions at around 5400 rpm
MILD THUNDER 11-21-2013 08:53 AM
The question is how many RPMs do your engines need? Are these 575HP 540's that only need 5200RPM, or 575HP 454's that need 5800RPM?
TomFTM 11-21-2013 09:06 AM
x2 that is what I had on mine when I sold it. ran into the 80's with 26 hydro's 580 hp .
indypromarine 11-21-2013 11:02 AM
575 hp 454
Unlimited jd 11-21-2013 12:28 PM
At what rpm???
indypromarine 11-21-2013 05:09 PM
machine shop is saying 5300
Griswald 11-22-2013 05:26 AM
Bblades has the test program which will let you try a few different props. I'd throw the 26s on there and let it eat.
MILD THUNDER 11-22-2013 06:29 AM
I wouldn't buy any props unless the engine was dyno'ed at a reputable shop. 575HP @ 5300 from a 454 is probably an unlikely number, unless they have blowers on them.
Id bolt the stock 25 3 blades on and go for a run. How much RPM you gain with those props, will give a good idea of how much power you picked up. One speed run shouldn't hurt anything if they still have the 440HP bottom ends or better, and a decent cam/springs. Then once you get those numbers, I'd call Bret at Bblades.
Fenderjack 11-22-2013 09:09 AM
Our 83 10 meter had 28 bravo's on it with 500 hp motors and bravo drives ran high 70's
perfspec 01-13-2014 06:07 PM
Could you post some good pics of your race fairing. Profile and some dimensions.
Would be greatly appreciated. Hope your project is advancing as you wanted.
