-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   What did Fountain use to coat the bilge area? (https://www.offshoreonly.com/forums/fountain/308968-what-did-fountain-use-coat-bilge-area.html)
zz28zz 02-24-2014 02:44 PM
Got the engs out and want to clean/paint the bilge area.
After reading a few threads on the subject, sounds like Sherwin Williams hi-solids polyurethane was a good choice.
I spoke to the sales rep at the industrial Sherwin Williams store. He wanted to know what coating was already in the bilge.
Did Fountain use polyurethane paint in 1990?
Thx in adv!!
38fountainecman 02-24-2014 04:09 PM
I would guess gel-coat
4bus 02-24-2014 06:41 PM
Two years ago I did a gallon of rustoleum white enamel mixed with hardener from a paint shop. Was cheap, dried rock hard, shines like new, and is fuel proof. I think the paint was $30 a gallon at Lowes, hardener was less than $10 bucks.
Use tin foil to wrap hoses and wires you don't want to get paint on. Faster than tape, and easier than removing the tight spots. Paint away and toss the foil when you are done.
zz28zz 02-24-2014 11:15 PM
That's a lot cheaper than the S/W paint. They quoted me $180/gal plus another $20 for the hardener.
What kind of surface prep did you do? Any sanding needed to help paint adhere?
The alum foil idea sounds a lot easier than taping everything.
4bus 02-25-2014 03:59 AM
I cleaned with water and a degreaser. Then hand wiped everything with acetone. No sanding.
Griswald 02-25-2014 05:34 AM
clean it, wipe it down with acetone and brush on a couple layers of Bilgekote. Bright, shiny white and will look brand new. West Marine - $35qt. You can probably get away with 1qt, no more than 2.
vintage chromoly 02-25-2014 06:54 AM
I would abrate the surface no matter what you finish it with.
