-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   prop LH and RH direction question (https://www.offshoreonly.com/forums/fountain/310855-prop-lh-rh-direction-question.html)
moderatedUser23082018 04-11-2014 08:06 PM
Never thought of writing down which side was the RH and LH before I sent my props to BBlades. Anyone want to clue me in as to what sides to put the props back on??
US1 Fountain 04-11-2014 08:19 PM
On your 32, the RH will go on the left side, the LH prop on the right. This is Fountains normal way of sending the boats out with the props spinning in.
On your 27, put the prop on the center drive. :)
WHIPLASH 04-11-2014 09:01 PM
I have a 94 32 Fever and the props spin out. I notice you have a 99 and he has a 2000. Did they change the rotation later when they made the stepped hulls?
US1 Fountain 04-11-2014 09:35 PM
That's been my understanding. Don't know if 100% correct or not, but knowing his is a 2000, figured pretty much safe to say. Plus a buddies 2000 spins in.
Dkahnjob 04-11-2014 10:10 PM
I had a 2000 35' Lightning Classic and the props Spun in, Right hand (clockwise rotation) on the Left and Left had (counter clockwise rotation) on the right.
Crude Intentions 04-11-2014 11:01 PM
To my knowledge fountain spins them in, however people switch them. It's easy to do. You may have to just try putting them on spinning in and bump in forward to see if it rotates the right way.
Port Monster 04-12-2014 04:07 AM
Find a picture of your boat on the trailer and take a look. That is what I did the first time I was sitting there with two props in my hands shaking my head.
