-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   charging battery with booster port under seat? (https://www.offshoreonly.com/forums/fountain/310874-charging-battery-booster-port-under-seat.html)
Crude Intentions 04-16-2014 07:38 PM
Originally Posted by Wildman_grafix (Post 4107612)
I am adding shore power and the charger I have can charge up to 3 banks independently.
When I used the charge port I just set it up in the mode that gives you higher current by using two of the independent chargers. Independent is better as the charger can tell a difference in each of the batteries but for what this guy wants to do the charge port worked fine for me.
You have to start putting it together first Phil. Haha
Wildman_grafix 04-16-2014 08:55 PM
Hey I put the cables in Saturday!
Thread high jack,,,,,,,
Crude Intentions 04-16-2014 10:06 PM
Drag it to my house. Or ill come get it. Ill put it together and use for it ya!! Haha
breakitout 04-17-2014 01:15 AM
Alright.. so trickle charger on the jumper port is what ill do. Wrecked agm blue top optima battery due to letting it sit dead too often.
I had to replace the Anderson plug also.. pretty easy to find them online or forklift supplier.
US1 Fountain 04-17-2014 06:51 AM
Use a float charger if you are just wanting to keep them topped off.
Jamie77905 04-17-2014 07:48 AM
Originally Posted by Cole2534 (Post 4105985)
Any idea where I can get one of these plugs? I'd like to make up some jumper cables since I don't have the factory ones.
I just bought some at a Interstate batteries store and the crimped them and made the cables up for me. So if you have one close try them.
Cole2534 04-17-2014 10:24 AM
I ordered a plug from eBay. Ill probably half a$$ crimp and then fill the lugs with solder.
HyFive578 04-17-2014 10:27 AM
Tried that.. couldn't heat the plug enough to get the solder to stick..
Cole2534 04-21-2014 05:15 PM
Did you use a torch? That's how I usually do large solder jobs.
253 04-29-2014 11:47 AM
I used a 2 amp trickle charger connected to the jumper cable port most all winter on mine, it worked great.
